FS: 2005-2015 Toyota Tacoma Rear Hydro Shocks Used 3K
Discussion in 'Classifieds' started by MattScatt425, Dec 18, 2017.
  1. Bojangles
    Bojangles Well-Known Member
    If so, free recall, safety oriented clock spring.
    Bogunn and MattScatt425 like this.
  3. Bogunn
    Now’s your chance to get a Dixie horn!
    OR17TRD and MattScatt425 like this.
  4. OP
    MattScatt425
    MattScatt425 Well-Known Member
    Or a train horn! Haha
    @Daca_taco, OR17TRD and Bogunn like this.
  5. OP
    MattScatt425
    So from what I have read. If the spiral cable goes out the horn, airbag light and cruise control won't work? Where is the relay located?
  6. Bogunn
    MattScatt425 likes this.
  7. OP
    MattScatt425
  8. OP
    MattScatt425
    My airbag light isn't on
  9. Bogunn
    Did you ever try your horn to the battery like @OR17TRD said? Maybe it’s a lot simpler repair than the spiral cable.
  10. OP
    MattScatt425
    I need to get some jumper cables before I try that
  11. Bogunn
    Are the fuses good? Wiring corroded or messed up?
    It’s easy for the wiring to get messed up and corroded where the horn is located in the Tacoma.
    Hopefully this is another simple repair like your last one!
  12. OP
    MattScatt425
    Yeah fuses are good. Replaced it just in case. I will look harder tomm. Yea I sure hope so! I'm just waiting to pull the trigger on the spiral cable..
    Bogunn likes this.
  13. OP
    MattScatt425
    I figured it out. The spiral cable is bad. Turned the steering wheel and the horn worked. Horn doesn't work with the steering wheel centered
    Bogunn and OR17TRD like this.
  14. OP
    MattScatt425
    So my next question is. Should I buy a cheap clock spring off ebay? Or a Used OEM one? Or brand new? Thanks guys
  15. OR17TRD
    My friends mom in high school had a car and when she would make a left hand turn it would start honking it wouldn’t work any other time, so we would hang out the windows and wave every time she would turn left haha. People be staring.
    @Daca_taco and Bogunn like this.
  16. Bogunn
    If it was me I’d get an OEM. Or at least one that’s made by a reputable company. lol. Maybe even salvage yard.
    Bojangles likes this.
  17. OP
    MattScatt425
    Would you go with a Used OEM?
  18. OR17TRD
    I think you’d be ok with one. Typically they last longer than the truck itself.
  19. Bogunn
    Absolutely. You’d be fine.
  20. OP
    MattScatt425
    Figured I would call Toyota corporate and ask if they would help. Said no but if there is a recall for the 2012 model they will reimburse me hahaha. Toyota is a joke sometimes.
    OR17TRD likes this.
  21. Bojangles
    Weak
