Help 2018 Tacoma
Discussion in 'General Tacoma Discussion' started by Paulie, Mar 22, 2019.
  1. Paulie
    Paulie Member
    The truck goes into drive but won’t go forward, it’s like the brakes are stuck. It’s now back at the dealership, has anyone have this problem.
    I have to turn the truck on and off 5 to 6 times, Before it will go.
  3. JimShep
    JimShep Well-Known Member
    Sounds like a sensor problem how many miles?
  4. whippersnapper02
    The drum brakes can stick in cold weather.
    Crawdad, Lil G and texasred like this.
  5. JimShep
    How cold is it where your at , have you tried not setting the park brake,
  6. Lil G
    Lil G Well-Known Member
    I’ve never had that problem. But like the other posters said cold weather will stick the drums. Not saying that’s the fix but its definitely something to think about
  7. pauljboudreau
    pauljboudreau Active Member
    Did you wash it and the temperature is freezing? Happened to me when i carwashed it and went shopping, the brake where frozen solid
    texasred and Bogunn like this.
  8. mk_taco17
    mk_taco17 New Member
    I had that issue once on my 2017 TRD off road manual trans. It felt like my brakes where locked up completely on all 4 corners. I ended up pushing the brake pedal and they let go. It's been a year and it hasn't happened since. It was in the summer time so probably around 75°f.
    texasred likes this.
  9. OP
    Paulie
    Paulie Member
    29,000 I bought it new
  10. OP
    Paulie
    Paulie Member
    I live in Arizona where it doesn’t freeze
    whippersnapper02 and texasred like this.
  11. OP
    Paulie
    Paulie Member
    Yeah it’s happen about 10 times, Toyota is sending out a field engineer to look at it on Monday
  12. OP
    Paulie
    Paulie Member
    No it’s warm here in AZ
    Taco Obsessor and texasred like this.
  13. OP
    Paulie
    Paulie Member
    It’s warm here in Arizona, I bought the Tacoma new it only has 29,000 miles on it. It has the same problem with or with out the E brake on
  14. OP
    Paulie
    Paulie Member
    I want to say thank you to everyone who has responded to this post, Toyota is sending a engineer out to look at the truck on Monday, they now will not give me my truck back because they say it’s now unsafe to drive.
    Taco Obsessor, Lil G and texasred like this.
  15. texasred
    texasred Well-Known Member
    Be SURE to keep us updated!
    Taco Obsessor and B-Man like this.
  16. whippersnapper02
    Hmm. Odd for sure. Hopefully they get it figured out.
    Taco Obsessor, B-Man and texasred like this.
  17. OP
    Paulie
    Paulie Member
    Update ,Toyota had there engineer out, they were unable to duplicate the problem. But they did replace the ABS system on the truck and a few other electrical systems that were connected to the brakes. So good news I have my truck back. So we are keeping our fingers crossed on this one IMG_4555.jpg
    Toki, texasred, B-Man and 2 others like this.
