Idle Issue
Discussion in '2016 + Toyota Tacoma' started by Gadget, Aug 10, 2017.
  1. Gadget
    Gadget Well-Known Member
    Well my 1st issue on the new Taco.
    With the A/C off the idle is fine. Right at 600 RPMs.
    With the A/C on the idle goes to 1100 RPMs then slowly deceases until 600 RPMs the it almost dies before going back to 1100 RPMs.
    Figure it is some thing like what we called in the old days A/C kick up RPMs so not to stall.
    Any advise is welcome. Kind of a DIY type and also the dealer is 5 hours away...
    Thank You,
    M
  3. jajlc070915
    jajlc070915 Active Member
    My 2017 off road dose the same thing.
  4. OP
    Gadget
    Have you had a Dealer look at it yet? If so, do they just call it normal? Seems odd...
    BTW - It does this with the trans is in park or neutral. Drive & Reverse it stays at 600 RPM
  5. Bogunn
    My 2017 does it too. I assume it's normal if they are all doing it.
  6. rippsgt
    rippsgt Member
    Yea mine does it too
    2017 trd
  7. Conceals
    Conceals Active Member
    Mine too
  8. Duff49
    Duff49 Member
    Mine too. It feels like the A/C compressor takes about 30% of the low end torque when trying to pull out on an incline.
    Bogunn likes this.
  9. Steepside
    Steepside Member
    Me as well!! Just noticed it today when I pulled over on the phone!! Thought it might be a common thing!!
    Bogunn likes this.
  10. Bogunn
    Apparently they are all doing it. It truly does feel like the RPM kick up on the old 4 bangers from years ago when the AC was on.
  11. OR17TRD
    I haven't paid any attention to this. I'll have to see if mine does it. I'm thinking yes.
  12. mcklovin77
    mcklovin77 Well-Known Member
    My 2017 trd off road does it as well. Its normal. The last 3 vehicles ive owned did the same thing.
  13. rrt1949
    rrt1949 Active Member
    I just think there is not enough torque to keep up with all the "stuff" that needs to be taken care of.
  14. Orangejulius
    Orangejulius Member
    I've always felt there was a "miss" while at idle, but maybe it's the A/C dragging it down?
    tomarx2taco likes this.
  15. dionnys
    dionnys Member
    mine does it but not all the time.
  16. 4wd
    4wd Well-Known Member
    Well gotta remember theres quite a bit of drag on power when compressor engages (which of course explains the high idle "kicking in" but to the issue of almost stalling almost sounds like a stammer in high idle sensor or throttle positioning sensor ...
  17. Brian Neil
    Brian Neil Member
    Hey I had the same problem, took to the dealer, updated the computer and it hasn't done it since.
