Lubricate propeller shaft interval
Discussion in 'Maintenance' started by Taco Slinger 4000, Apr 15, 2018.
  1. Bogunn
    Haha. For sure.
    You’re hard core if you’re polishing your shaft with brake cleaner. Most use lotion.....
    B-Man and whippersnapper02 like this.
  3. OR17TRD
    SCH, B-Man, Bogunn and 1 other person like this.
  4. jrct84
    jrct84 Well-Known Member
    Where is the fitting to grease the fan?
  5. whippersnapper02
    There's not fitting for the fan and only 4wds (2nd gens) have driveshaft fittings.
    B-Man likes this.
  6. jrct84
    I have a 2014 4wd how do you lubricate the fan? Because it says it in the owners Manual
  7. jdr3366
    jdr3366 Well-Known Member
    Is there a upgrade I'm not aware of. I don't think I have a propeller attached to my Taco.
    But these guys do. Or should.
    Bogunn, OR17TRD and whippersnapper02 like this.
  8. OR17TRD
    That’s awsome. Those are heavy enough they don’t need props just keep it gassed.
    Bogunn likes this.
  9. Bogunn
    In Iraq in 2003 there were a plethora of old Soviet era Russian 5 ton size trucks around that we would “borrow” to get around. Those things rode like gut wagons but were impossible to kill.
    tman and Montague like this.
  10. Joisey
    Joisey Well-Known Member
    I put all of my worn out work socks in a bag (after washing them) and save them for when I grease anything. Slip on a Harbor Freight black glove, slide the sock over your gloved hand and you have an easy way to wipe up any mess that you make. It's not like the old socks are good for anything else.
    texasred, kp.taco, OR17TRD and 2 others like this.
  11. OR17TRD
    texasred, B-Man, Bogunn and 1 other person like this.
  12. Joisey
    I put the eyes and hair on AFTER I use the sock to wipe up the grease.
    Lil G, texasred, OR17TRD and 3 others like this.
  13. kp.taco
    kp.taco Well-Known Member
    Makes it more absorbent
    Lil G, texasred, OR17TRD and 2 others like this.
  14. Bogunn
    Not a bad idea.
    But your wife probably wonders why you have so many happy socks in the garage.
    Lil G, texasred, kp.taco and 2 others like this.
  15. OR17TRD
    Haha
    Lil G, texasred and kp.taco like this.
  16. Joisey
    Ten times more absorbent than the leading paper towel.
    OR17TRD, Lil G and kp.taco like this.
  17. Joisey
    I wonder if the original poster was speaking of the slip joint in the driveshaft? All Tacomas have that, or no??
