Manual trans — trouble shifting into 1st
Discussion in '2016 + Toyota Tacoma' started by warmfuzzies, Dec 4, 2018.
  1. OP
    warmfuzzies
    warmfuzzies Well-Known Member
    It’s not driver error when you’re in a parking spot, clutch is fully engaged, and it’s not letting you access first but every other gear is open
    But I wish it was driver error, then I’d at least know what was going on. Ha
    manual tacoma likes this.
  3. OP
    warmfuzzies
    New development: after parked for awhile, huge clunk when attempting reverse.
    Feels like the parking brake is engaged but it isn’t and it takes a good amount of gas to power through the resistance, huge mechanical clunk and bang. Recorded it on video twice and it happened a total of 3x today.
    No warning lights, parking brake off, and everything works fine once I’m moving. Reverse is ok after driving for a bit, just that initial parking that does it.
    I’m awaiting the dealer response since I emailed them the videos.
  4. geekyadam
    geekyadam Well-Known Member
    I'd take it in for sure
  5. OP
    warmfuzzies
    Still awaiting an official diagnosis but I suspect it may be the parking brake freezing to the rear drum brakes — will post what I find out when I get the truck back.
    Either way this shouldn’t be happening in 2018.
    B-Man likes this.
  6. Joisey
    Joisey Well-Known Member
    How that would influence the transmission confuses me. Also seems to confuse the dealer.
  7. OP
    warmfuzzies
    It’s likely an entirely separate issue but since I was the OP on this thread I threw it in here.
    You’re right, def unrelated but potentially trans related.
    When I got the truck back they logged my new issue for the record but didn’t do any fixes.
    Separately also had the TSB 0059-18 for disabling the pre-collision system done but it didn’t seem to work. It restarts when the truck is turned back on again — I’ll be going back.
  8. krt~fabs
    krt~fabs Member
    My truck did the same thing. It is the rear brake delaying. I forgot what the part is in the brake line that balances the braking power, but that sticks when it’s older.
    Malicious Mike likes this.
