Oil reset.
Discussion in 'Maintenance' started by fordjonp, Aug 4, 2017.
  1. fordjonp
    fordjonp Member
    Will disconnect of battery reset ,maintenance required, for oil change?
  3. whippersnapper02
    Per the manual:
    Black gauges: Select ODO with the truck off, hold the trip button and turn the key to on. You will see a "countdown" and then a flashing of all 0's. Release and it's done.
    White gauges: Same procedure as above but you select trip A instead of ODO.
  4. OP
    fordjonp Member
    That's not what I mean . If I have disconnected batteries will the maintenance required still keeep track of miles till oil change.
  5. whippersnapper02
    Oh yeah it will keep the mileage.
    Bojangles likes this.
  6. RPV3013
    RPV3013 New Member
    YouTube explains how to reset maintenance light
