I found out my passenger side window won't go up or down, 4k on the truck has there been any issues others have had? I tried the switch on my side and the drivers side as well thought it might have frozen but not theta cold in the thirties here and the drivers side works fine. I have to take truck in for 5kin couple of weeks and they said they would check it out . Any ideas as to what it might and if they can fix it without beating the hell out of the truck? Thanks John
Join TacomaForum.com Today - It's Totally Free! Are you a Toyota truck fan? If so we invite you to join TacomaForum.com. Our site is specifically designed for you and it's a great place for Toyota Tacoma Fans to meet online. Once you join you'll be able to post messages, upload pictures of your truck, and have a great time with other Toyota Tacoma fans. Whether your an old timer or just bought your Tacoma you'll find that TacomaForum.com is a great community to join. Best of all it's totally free! Join TacomaForum.com Today!
If neither switch works it's something they have in common. Likely a relay, motor, or fuse. They each have their own fuse I believe.
My 18 taco has 18,000 and started to do the same thing on the rear passenger window. If I turn the ignition off and back on it’s seems to fix. Still need to go to the dealership to address the issue
