Random acceleration when cruising
Discussion in '2016 + Toyota Tacoma' started by eaglecurt, Nov 2, 2018.
  1. eaglecurt
    eaglecurt New Member
    Sometimes,not in a high rpm my Tacoma accelerates on its own while cruising. Any thoughts? 2016 Trd 4x4 manual trans.
  3. whippersnapper02
    Do you have stacked floor mats? Are you using cruise control? How much acceleration are we talking?
  4. OP
    eaglecurt
    No, it’s the trans. When I’m going up to speed at moderate rpm sometimes it accelerates suddenly. Similar to a Honda with vtech when shifting through high rpm.
  5. Joisey
    Joisey Member
    Is actual road speed increasing, or just engine RPM?
    You didn't state if you have the 4 cyl or the V6. My 2018 auto V6 will take off like a scalded cat when it hits about 3600 rpm. Does it every time.
  6. whippersnapper02
    If it's the V6, then probably just the ECU switching injection modes.
    yvesmartin and OR17TRD like this.
  7. OP
    eaglecurt
    Correct. It’s the V6. I was thinking ECU as well. Nothing abnormal.
  8. whippersnapper02
    Some have reported a slight surge when it happens. The manual tranny will transmit that surge more directly than an auto. The explanation was the switch to all 12 injectors firing or something like that.
    Bogunn likes this.
  9. OP
    eaglecurt
    Sounds good. Thanks for the help.
