Remote start compustart
Discussion in 'Aftermarket Products, Reviews & Installation' started by MacGyver, Jan 28, 2019.
  1. MacGyver
    MacGyver Well-Known Member
    So just had the compustart pro 3 installed on a 2019 TRDS manual. Eh...once I figured out what reservation mode was, I love it. Make sure you give the parking brake an extra tug before you exit. Screenshot_20190128-190516.jpeg
    Bogunn and Lil G like this.
  3. Lil G
    Lil G Well-Known Member
    I haven’t seen that brand before I will look it up
  4. dirtytaco
    dirtytaco Well-Known Member
    I had one of the compustar kits on a past vehicle. I liked it. There is a company that makes a plug and play remote start kit that utilizes your factory key fob (press lock button 3 times and it starts) but with the push button start in the new Tacoma’s, as soon as the door opens the truck shuts off and you have to restart it. I understand there is no bypass for that on that kit. Does this compustar kit work the same way?
    Bogunn, B-Man and Lil G like this.
  5. Lil G
    That’s a 12volt solution kit that dies when the door opens. I haven’t researched the other kit yet.
    B-Man likes this.
  6. OP
    MacGyver
    I will look out for it tomorrow morning and let you know.
    Lil G and B-Man like this.
  7. OP
    MacGyver
    So the only time it shuts off"" is if you get in, don't turn the key to on and press the break.
  8. OP
    MacGyver
    It stayed on more then 10 mins bit shut off when I pressed the break without having the key is.
  9. Lil G
    Mine is push button but I bet it has something to do with the brake switch. Thank you for the update
  10. OP
    MacGyver
    It does, anti theft feature.
  11. pauljboudreau
    pauljboudreau Active Member
    Automatic truck have keyless system, for some reason the manual don’t
  12. larryhorner732000
    larryhorner732000 New Member
    Does anyone know what range the 12v solution has?
    B-Man likes this.
  13. Bogunn
    The 12 volt solutions uses your OEM fob. So what you get with your regular key.
    B-Man and larryhorner732000 like this.
  14. B-Man
    B-Man Well-Known Member
    I've been as far away as about 75 ft and inside a building and mine worked!
  15. baldy54
    baldy54 New Member
    I wished they made them for the 06. Has anyone heard of mobokey.com?? I hear some reviews about them.
