Replacement axle gears
Discussion in '2016 + Toyota Tacoma' started by Joisey, Nov 2, 2018.
  1. Joisey
    Joisey Well-Known Member
    Are there any companies that make gears for the 2018 TRD off road Tacoma in other than stock ratios? I'm looking for something in the 4.30 to 4.88 range.
    I used the search feature and could find no postings. If I missed something that was posted, please supply a link.
    Thank you.
  3. whippersnapper02
    These guys will set you up with whatever you need: https://eastcoastgearsupply.com/
    OR17TRD likes this.
  4. geekyadam
    geekyadam Well-Known Member
    I think Nitro does third gen gears. That's where Maxx Powell got his done
    TacoBOB77 and Camren Harris like this.
  5. OP
    Joisey
    Thank you gentlemen. I dealt with East Coast Gear years back when I did an F-250 and a power wagon.
    TacoBOB77 and whippersnapper02 like this.
  6. Crawdad
    Crawdad Well-Known Member
    TacoBOB77, Camren Harris and OR17TRD like this.
  7. OR17TRD
    TacoBOB77 likes this.
  8. OR17TRD
    Welcome to the forum. Post some pictures of your OR.
  9. Crawdad
    Not till I have the gears and lockers installed. Lol
    OR17TRD likes this.
  10. OP
    Joisey
    I will, as soon as it stops raining.
    Seems I was a bit off in my calculations. 4.88 gears would put me more where the engine should be at 60 and 70 mph.
    OR17TRD likes this.
  11. OR17TRD
    4:88’s are good for the taco with 2-3” lift and 33’s you could even go to 35’s with those.
    4:56’s can do 32-33” easy if you know you’re not going to want to go bigger.
  12. OP
    Joisey
    I want to stay with stock height (30.61 to 31) and 4.56 will give me 1742 rpm, 4.88 will give me 1864 rpm. Compared to my current 3.91 ratio, which gives me 1494 rpm, way out of the torque curve, even if I run 70 mph the slightest hill makes the trans downshift at least one gear, sometimes two.
    TacoBOB77 and Crawdad like this.
  13. Crawdad
    There's such little difference between 4.56 and 4.88, you might as well just go 4.88. A 265/75- 16 is a nice size for stock height. I'm at high elevation and feel your pain... gears are on my list too, I never use 5th or 6th until I'm going downhill and over 60. Haha
