Shock replacement interval or failure?
Discussion in 'Maintenance' started by Taco Slinger 4000, Apr 13, 2018.
  1. Taco Slinger 4000
    Taco Slinger 4000 Well-Known Member
    are shocks the type of part that need to be replaced regularly at a specific mileage interval? Or only when they fail? I want to maintain my truck with stock suspension but cost is also an issue. Thanks
  3. whippersnapper02
    Only when they fail and there's no knowing when since roads are different everywhere and also depends on your use.
  4. OR17TRD
    Give it the bounce test. Push on each corner and make it bounce. Good shocks should settle at ride height in a bounce or two. If its bouncing like a ho on coke it’s no good.
  5. OP
    Taco Slinger 4000
    Thank you. I will call my local Toyota dealership to schedule a bouncing like a ho on coke test and possibly a quote for a set of shocks.
    cthetaco, kp.taco, B-Man and 2 others like this.
  6. Bogunn
    Haha. “Ho on coke” test. Is that the official name?
    B-Man likes this.
  7. OP
    Taco Slinger 4000
    No. I just spoke with a service advisor apparently it’s just called a “bounce test”. To save anyone the hassle of asking for the wrong test when you call the Toyota service center.
    B-Man, OR17TRD and Bogunn like this.
  8. Bogunn
    Lol. Good to know. Thanks for clarifying. It may be a little awkward when you call the service department and ask for a bouncing coke ho.
  9. OR17TRD
    You might be suprised... when you ask.
    Bogunn likes this.
  10. OR17TRD
    Yes.
    vwgtiturbo and Bogunn like this.
  11. vwgtiturbo
    vwgtiturbo Well-Known Member
    "Ho on coke"... I really need to work that into my conversation today.
  12. OR17TRD
    What did they say?
  13. OP
    Taco Slinger 4000
    About the “ho on coke test”? They said they didn’t have the proper equipment to perform the test. Nor would they take my word and cited that it would be an issue that the technician would have to replicate in person with the proper equipment.
    Bojangles, Bogunn and OR17TRD like this.
  14. OR17TRD
    ROFL. Nice.
  15. OR17TRD
    Not really. I was however wondering if you actually took it to see if you needed new shocks or not.
  16. Bogunn
    Hahahaha
  17. OP
    Taco Slinger 4000
    Not yet, I’ll check it myself or per their recommendation. I should be ok for a while bc the most non pavement driving I do at this point is a 1.5 mile unpaved road to and from work
    OR17TRD likes this.
