Strange noise under hard acceleration
Discussion in 'Maintenance' started by ssmalley41, Sep 12, 2017.
  1. ssmalley41
    ssmalley41 Member
    I need some help. I noticed today that under hard acceleration there is a strange clunk or rattle coming from somewhere under the truck. It's a 2013, 4.0, 4x4, double cab, automatic with around 75,000 miles. It's bone stock, no mods. I've seen a lot of stuff about driveshaft noise, but this is not a constant noise. I get the noise briefly when accelerating hard up to 40mph, and only on or after the initial downshift. After that, it seems normal. Any info at all would be appreciated. Thanks.
  3. whippersnapper02
    I'd check U bolt torque. It should be 75 ft lbs.
    4wd likes this.
  4. OP
    ssmalley41
    ssmalley41 Member
    Thanks!
  5. OR17TRD
    I think I'm understanding... you take off from a stop with constant acceleration and as soon as you let up you hear a clunk happen. You notice no clunk at the immediate acceleration or during acceleration only when you let off the peddle after reaching your desired speed. Is that right?
  6. OR17TRD
    I'd do what whippersnapper02 suggested. I'd also check the tranny fluid, diff fluids and grease the zerks. If you have never done a fluid flush on any of those I would suggest doing them.
    whippersnapper02 likes this.
  7. whippersnapper02
    Definitely zerks.
  8. OP
    ssmalley41
    ssmalley41 Member
    No, immediately after pushing the pedal down. No noise after let off.
  9. OR17TRD
    Acceleration from a stop transmission makes one hard clunk with the first to second gear down shift and then normal driving after that. And it's only when you accelerate hard. I'd do all of the above stated if it hasn't been done and see how it operates after that.
  10. whippersnapper02
    Might also be the slip yoke. You can't service it without puling the entire shaft out though.
  11. Bojangles
    Bojangles Well-Known Member
    :cool:
    You go Nancy
    Bogunn and whippersnapper02 like this.
  12. Bogunn
    That’s why he has all those trophy points!
    Bojangles likes this.
  13. Bojangles
    service with a smile
    Bogunn likes this.
  14. OP
    ssmalley41
    ssmalley41 Member
    I checked underneath today. U joints seem ok, but there is a ton of radial play in the carrier bearing.
  15. whippersnapper02
    Normal. It's not a solid mount.
    4wd and Bogunn like this.
  16. 4wd
    4wd Well-Known Member
    Just a note to those inquiring, it would help TONS if any audio/video can accompany the description of noises made, I know one guy on another forum had complained that when he started truck it would make a "clang with a constant knock that changed with rpm, he posted up short vid & within 15 sec. of play it was clear he was about to have a rod come thru the block, point is there's no substitute for being there & next best thing is audio/visual help...
