So your saying a 65mm tire will poke out the same or no different than an 85mm tire? Come on!
Are we taking about LEGO tires now? RC cars? I guess I’ll play.
A 65mm tire is going to be 20mm shorter than a 85mm tire. The width could be the same. You’re taking about 2.5 inch tires compared to 3.3 inch tires.
If you’re referring to a 265/65/18 vs a 285/65/18 the width is going to be 0.8” wider in total which will only give you 0.4” of “poke” or “stance” that’s equal to 10mm of negative offset.
What I was saying was a wider tire alone isn’t going to give you a “lot” of stance. You said “Yes it does,tires are made wider they have a
lot to do with stance” I said “I wouldn’t say a lot. They have some effect on it” Most people are looking for at least 1-2” of poke when they want a wide or aggressive stance.
Changing the wheel offset can give a greater stance then a wider tire. Even more when paired with a wider tire. You’re going to need a lower offset (or wheel spacer) to run a 285 on the Tacoma anyways. If you put them on a stock wheel they will rub the control arm.
A zero or -6 offset works well with a 285. You'll also need at least a 2” lift.
285/65/18 with a -6 offset will give you about 1.6” of poke for a more aggressive stance. Compared to a +25 OEM wheel with 285/65/18 at 0.4” of poke. You get 1.2” more with offset. Or you can get a 1.25” wheel spacer to achieve the same thing.
I stand by my previous statement.
