Transmission flush
Mark a bucket for one or two quarts. Pull the return from the cooler and run it to said bucket. Start the engine and fill the bucket until your mark. Kill the engine and fill the trans with new fluid at the pan. Dump the bucket and repeat until you have gone through all the fluid capacity.
Running through the gears will flush the valvebody.
Do this at your own risk.
So basically, i should just go to my mechanic?
You shift through the gears like normal...Yes you will eventually get all the fluid out.
I think you should leave this to the mechanic.
