Rusty Shakelford
Vehicle: 2001 Tacoma 2wd, 2.4L
My last set of brake pads only got about 10k miles on them before the wear indicator started screeching. Evidently my brakes had been dragging, not sure for how long. I replaced my front drivers side caliper when I replaced the pads 10k miles ago, and I thought now the passenger side caliper was sticking, so I just replaced it, put in new pads, bled the system, and it still drags. It is just the front wheels that are dragging. It takes two hands to turn the hub. When I take off the caliper it spins freely.
So yesterday I replaced the master cylinder, bled the lines in the proper order and the proportioning valve (rear passenger, rear drivers, front passenger, front drivers, proportioning valve). Still dragging!
Today I did some more troubleshooting. I'm getting flow to the calipers. If I open the bleed valve I get a slow gravity flow. When I flip up the caliper and watch the piston while my helper presses the brake it appears to be working properly. It extends when the brake is pressed and retracts slightly when they let off the brake.
I also tried loosening the master cylinder from the brake booster to see if perhaps the push rod was an issue. I loosened the MC as far as I could without taking the two bolts all the way off, I'd say about 8 mm. Still no bueno. WTF?
Can anyone help me out? My thoughts are bad brake hoses (I ordered two which should be in Wednesday next week just in case). Brake booster? Proportioning valve? I'm tired of throwing parts at this thing. Any help? I'm losing sleep over this thing beating me.
Thanks!
Thanks!
