Hello al.l I own a 2017 Tacoma TRD 4x4 Off Road.  I have a question for you. I have been told to use Genuine Toyoto API SN SAE 0W-20 Motor oil with oil grade  ILSAC  GF-5 for oil changes. However, my service department  uses bulk Mobil 1 synthetic.
1. Is the Mobil 1 used for oil changes compatible with Genuine Toyota motor oil.
2. Is the Mobil 1 oil SAE 0W-20 and ILSAC GF-5 specs as recommended by Toyota?
2. Is it safe to switch from Genuine Toyota Motor oil to the Mobil 1 Synthetic?
3. It appears the Mobil 1 synthetic oil is a little cheaper then the Genuine Toyota synthetic.
Can I purchase the Mobil 1 Synthetic oil at a parts store if in fact it is compatible and OK to
use?
I just want to make sure that I am doing what is right for my Tacoma without causing any harm. You advise and knowledge is important and means alot. And I do not want to mess with my warranty.
Awaiting your response and thank you in advance.
use?
