Hi guys! Im looking to buy a 2nd gen tacoma (2011-2014) of course used, what are the first things I need to do when I go to see them, as well as what are the things I should check for used 2nd gen tacos?
Frame rust if earlier years like 2011 or 2012 (look for fist-sized holes near the catalytic converters)
Steering rack leak near the tie rod bellows
Timing cover leak near the power steering pump (V6)
Rotted out radiator support bushings
Worn out wheel bearings
Coolant leak near the firewall (V6)
Cracked coolant pipe under the intake manifold if 2011 (I-4)
A/C leak at the high-pressure line going to the condenser
Squeaky clutch due to worn-out throwout bearing quill on the bellhousing (manual transmission)
