I tried my tacoma with the chin spoiler removed....lost about 1mpg, and got more wind noise. I couldn't tell any odd effects on the trucks handling.
Right?!?! It was especially noticeable when passing trailer trucks.
Never notice anything like that with my sr5 when on the interstate with big rigs....truck was very stable. I only noticed i had more wind noise around 45 mph and above. I've got a tonneau cover if that makes any difference, idk.
a big rig tractor with trailer almost sandwiched my little rig on the 75 freeway onramp today :eek:, i had no clue what they were doing, i thought they were getting on the freeway slowly with a very large load of timber at maybe 25mph... all of a sudden they head for the shoulder leaving me trying to merge into some 70mph traffic with dumazzes behind me riding my six and no shoulder to maneuver since they were blocking it :mad:
Seeing as I drive one for a living. I’m still trying to figure out how a slow rig in a breakdown lane you on an entrance ramp and obviously a full right lane could of sandwiched you. Oh right if you don’t yield sure you’re gonna get sandwiched. people on your 6 should know better but no one does these days.
This entrance ramp had a decent incline if it matters? I was watching his turn signals and for sure I thought his left signals were on that he wanted to merge into the freeway
They pulled over abruptly but kept moving in the shoulder lane mere feet away from the freeway with those fast moving cars in both lanes iirc now it happened so fast and unexpectedly with the vehicles behind I jumping around crossing the solid white line
The worst thing they did was govern the semi rigs. Making it virtually impossible to speed up to avoid instances like this that I call the squeeze play. The truck is basically a prisoner and everything around him are escapee’s. Ya ever wonder why trucks just stay in the middle lane? This is why.
They do not have those acceleration lanes around here! I did see some of those in Minnesota recently specially marked
They stay in the middle lane till they come up on slower traffic. It doesn't take for these guys long to get a head of steam to pass on the outer lane. Traffic on the interstate ca get pretty heavy at certain hours. Soon as you see an opening to pass a slow vehicle, you gotta go for it before it closes, or you get hung out to dry. I swear its turned into nascar around here.
Can these big rigs just stop on a dime hauling a megaload?
I do not trust that they can, especially on the downhill grades, I see them lose speed going small uphill grades
Aren't they just a mini train with that weight?
Gave underbody a good hosing down
Looks like the woolWax on the diff housing cover needs touched up
Or should I remove all that WW and start with a new fresh coat after checking on the primer I put on that some years ago IMG_20220802_143316_668.jpg
gittin' a full body soak felt good in the 99 degree heat LOL
I think you answered yourself with that final question.
Was that the way the wool wax went on and setup, or was it sprayed over a crusty undercarriage at the time?
i notice that lumpy & uneven appearance also!
a few years ago i spent some good time hunkered underneath removing the axle crust i could reach with the abrasive blaster gun right down to the bare silver metal, then a couple coats of black primer
initially i recall using some loctite naval jelly to dissolve the crust but that went nowhere in a hurry
then sprayed some black woolwax for a groovy dark appearance under there that is visible to vehicles from behind. sprayed another coating on there before the next winter
the lumpy appearance i am going to say comes from the highway wind and blowing it up from underneath when things get hot... plus all of the dirt that has collected to it and the respray touchups on occasion
now i could clean all the wax off and then brush some of that cosmoline rp-342 to see how i like it... the only bad thing is if i don't like it the laboured effort it will take to remove it :( and it may look funky around the rear diff checklevel plug after awhile
I did my gen1 tundra undercarriage best as possible wire wheeling all the crusty rust off. Then i used a rustoleum rust converter. 2 days later after that was good and dry, i painted it over with a brush using some rustoleum oil based black paint. It looked pretty decent when all was finished. I later fluid flimed it every year.
I did my 2020 tacoma when everything was still very new with cosmoline....over 2 years later still looks brand new, no lumpy or uneven coating. Even on my final toyotacare visit, they asked whats on there that it was still looked so new like it just rolled off their lot.
