'97 Taco life + times, the chronicles of...
page four...
9-01-22
old vs new front shock bolts + old links
those stabilzer bar links can and do snap break as exampled by these from Denver on the +700k superCharged '97
the paint in the shock tower cavities ought to be cured enough to get the new quikStruts installed today
either it makes a world of difference or it does not... i only have to wheel down the street maybe 100 feet to find out on that broken road
or will i need to get into some new UCAs because bushings are shot, how do you test and evalutate them there bushings that cannot be seen well
that was definitely an ordeal getting those quickStruts on yesterday, worse when found the Monroe factory did not assembly the top part proper and had to compress the spring to orientate the mount insulator in the proper direction for it to slip in with ease
now my inner upper back shoulder area is all buggered up :( from trying hard to press the LCA down enough to wiggle the first attempted install on driver side before noticing and investigating the defect
looking at prior pics the lower washer on those MOOG stabilizer links may be installed improper :eek:
i thought i was gonna catch a small break from being cramped under the taco for a spell before much more needed repair before that winter monster cometh :(
heading out to land of stinkin' linkin'
... will be a good test on these new quickStruts over that rough Quincy bridge on the Mississippi if its as rough as was the last time i wheeled onit
wheelin' the '97 on the 97 on 9-7
truckin' it thru Havana and Cuba :confused:
the bridge to Quincy must have been resurfaced because it wasn't nearly as harsh as i recall from many months ago
but that climb up from the river crossing was still broken as ever
almost 1100 mile roundTrip adventure to Springfield
2 days for that converter to cure so will need to get a topcoat chassis paint onit when it warms up later, it was a tad chilly last night, under 50F
getting the tires rotated today, its been a spell
i found this pointer video quite intresting + informative
... making a run into Des Moines today for some business
then going to check on by this place that popped up from where
to see if they got what i need to get done on the truck
https://merrillaxleandwheel.com/
https://merrillaxleandwheel.com/services/
staticmap
3000v
the stop-by the Merrillaxleandwheel shop in Des Moines was a disappointment :( its circle back to the base1 again
in jest they told me i ought to relocate to Oklahoma or the Texas panhandle...
what to do now
secured appointment at TCCN in the 'burbs for the cold weather issue that popped up last year
fingers crossed that the weather in November is cold enough for it to trigger and get fixed right...
weather permitting i am going to try and assist the nephew at replacing all 4 corners on his Sebring suspension parts... says he got the good stuff from the RockAuto but needs to compress the front coils since no assemblies are made for it
things got a tad intresting at the nephews yesterday, those spring compressor stix became all tangled up :eek:
headed south of KCK today on the 69 to the 59 in OK ending up somewhere in AR
on the hunt for tiger trail 90 in SW Missouri
it's in a rugged area, very hilly and very curvy
I am glad that there is no icing in a 100 degree swamp :oops:
should hit 270k near KCMO on the way back north
