I've decided to leave the Gen1 trucks alone because of the 4-sped automatic. The potential difficulty with this is that most the the Gen2 crew cabs I've found available feature the larger 4.0 L instead of the 2.7 L but this may be how the crew cab was always equipped.
I've learned the frame was still an issue but how far into the Gen2 model years? I've used the Carfax VIN check for open recalls and wonder if this is sufficient for the evaluating this issue. If not, what is the best method to determine if the frame was replaced? That is apart from visually inspecting it...
Our needs are: Crew Cab, auto is best but not mandatory, 4WD, A/C, bed length does not matter.
Please advise, caution or warn if necessary. I will restrict my attention to the known good model years.
Edit - The long bed crew/double cab will be best for our needs but I need to know overall vehicle length. Is it too long for our attached garage?
