Good lesson in diagnostics and not listening to the owner's diagnosis.
Just listen to the symptoms as the owner describes then replicate and diagnose.
Often the fix is not the most complex or expensive.
How would a throwout bearing get launched into a moving fan blade when this bearing in incased inside the bell housing. Makes more sense if the clutch pressure plate.boy, you fail to understand i have a desire to know whut is going on so i can get ahead before a major break happens like whut happened with the throwout bearing launching into a moving fan blade
or if its just nothing to worry about
these automotive 'experts' are well trained and should know EXACTLY what is going on from experience and training
Imo, after hearing that video, you've got bigger issues than only a throw-out bearing.this noise here was at its worst, day or two before it broke getting off the highway
diagnosed on multi occasions over a year and nearly 100k miles as throwout bearing by master certed ASE toyota master
Now someone is making sense of this.@tacojoel
Careful. You're not getting the full story. You'd have to dig through a lot of sand to find the grain of rice.
Short version.......as I recall from the multitude of threads.
Noise was diagnosed as a failing clutch on the A/C. Owner was convinced it was the clutch throw-out bearing and labeled the mechanic an ID10T. Drove it for roughly 4 months before the catastrophic failure.
