Continuing to try to track down why I'm getting water in passenger floor on my 1999 Prerunner when it rains hard, I'm about 10 hours into trying to figure it out and am not any closer now than when I started.  Anyone have issues with water getting in around the seals on these two things that go through firewall on passenger side in photo below?  I'm assuming one is the windshield wiper motor and the other goes to HVAC.  They are not watertight.
I've checked A/C water drain and it's not clogged, so pretty sure it isn't that. Took fender off today and nothing looks out of place and the cowl drains water, so its not clogged up there.
My latest theory is that water is running down the firewall and getting into the cab that way. The cowl design on passenger side is different than driver side. On driver side it comes off windshield and is able to go through the cowl trim cover and drains right out. The passenger side doesn't allow the water to travel the same way because the whole passenger side is one sealed unit, which I presume is to protect the windshield wiper mechanism. The problem with that is heavy rain causes water to go down the firewall. Pretty sure that's where the water is coming from that's on my passenger floor.
I'm trying to avoid taking the whole dash off in order to seal the firewall from the cab interior. That seems like it would be a pain in the a$$. Any other thoughts on someplace else that needs to sealed? Would take some pretty small hands to get inside the cowl space on passenger side, so if it's that I'm screwed. Appreciate any help. Thanks!
