2010 Tacoma Regular cab Leveling Kit?
Cody E
I recently purchased a 2010 Toyota Tacoma Regular cab 4x4. I'm not sure how many inches in the front it will take to make the truck completely level. When I was younger I had a 2001 taco and put 2.5" and it was noticeably higher in the front. I was disappointed. So if y'all could please help. Also I want to keep the rear end stock. I've seen 2" 2.5" and 2.75" for my year. So I just need some recommendations. Thanks y'all!
Blocks would ruin your ride. Stay away
2014 TRD, Stage 4 Icon Suspension, Toyo 33 A/T, Method Mesh 16inch Wheels, Apex 30" LED light bar
You have to pull them off the truck and pull them apart to do the adjustment so you have to choose where you want the lower mount to be before you install it.
.85 should but every truck is different. A good way to figure out where you want the front of the truck to sit is to use a jack on the front. Measure hub to fender as I on a level ground. Lift the truck to where you want it to sit and measure again.
Your truck is my trucks twin!!
I install a complete kit leveling dynastars 2.5 "front and 1" rear and gives a great look and the rear is still a bit more higher than the front
This is my 2014 on old man emu 884'S with nitro chargers.1" TOYTECH blocks in rear. East coast gear supply bushing in the front diff.rides smooth and pretty.20150103_164209.webp20150103_164220.webp 20150103_164209.webp 20150103_164220.webp 20150103_164209.webp 20150103_164220.webp
ImageUploadedByTaco Forum1420347995.219868.webpImageUploadedByTaco Forum1420348041.025137.webp
This is my 14 Tacoma... With a 3 inch lift.... The only thing I don't like is that there is a slight bounce in the front when you take off.
No. Never use spacer lifts. They usually always make the ride worse and they can cause suspension damage.
This just shows how little you know. Spacers WILL retain factory ride. Installing Bilsteins are great no doubt but there is no settling with spacers. As long as your spacers stay within the 2inch limit, there is no harm done to the truck. Leveling a truck even with Bilsteins will cause wear on ball joints.
