whippersnapper02
Negative Nancy
Nah. The mount is from Cravenspeed, the A/F gauge from AEM and the boost gauge from Speedhut.
Ok. Looks good mounted there. I know URD has something similar to that kind of gauge pod. How did you hook up for your air fuel ratio? Did you tap into a sensor?
URD sells the Craven pod.
The A/F unit has its own sensor. You have to get the bung welded into the exhaust and then you mount the sensor.
Thanks for the info. I did not they were the same. So I take it you had to cut a hole and weld the sensor in? Sorry for all the questions on this but this is something I have yet to do.
Have you changed anything else? Thermostat, MAF, ect?
Yeah just a hole but it has to be in a certain place.
Nothing else done to the engine besides the blower and exhaust.
Great. Lol. Ok so how did you determine where it goes? I Don't really want to mess that up.
It's something like no further than 12 inches from the head down the exhaust. Then you have to angle it so that moisture doesn't build up in it. I haven't fully read the instructions.
I'm letting a shop handle that one.
	Did you change you MAF sensor when you added the CAI?
Yeah that would be a mean set up
Sorry whipper. I meant did you have any problems with it running to lean with the CAI. When I had mine installed they told me I couldn't run a CAI. But I've been looking at the URD and the MAF sensor. Having gadget and his team set up the sensor to the set up I want to run. Any ideas or advice?
