Headlight adjustment is confusing me.
Seems pretty straight forward to me
Horizontal means Left to right
Vertical means up and down
Turn the upper right screw clockwise(to the right) to make the light shine more to the left and counter clockwise(to the left) shines more to the right
Turn lower left screw clockwise(to the right) to make the light shine higher or up towards the sky turn it counter clockwise(to the left) to make it shine towards the ground.
If you are standing in front of the truck reaching in and over the light housing and turning the screw to your left that's clockwise and right is counter clockwise to the light housing.
If you are standing and looking at it as seen in the manual picture turning the screw to your right is clockwise. Left is counter clockwise.
The manual is confusing and these screws are almost breaking off. Any information ?View attachment 11681
Maybe spray a little panther piss on them.
Why are you adjusting them? Did you replace the lights? Get a lift? Just want to?
If you are standing in front of the truck reaching in amd over the light housing and turning the screw to your left that's clockwise and right is counter clockwise to the light housing.
I feel that instruction #2 describes the opposite direction adjustment screws.
I see what you're seeing now.
Could be that or they labeled the diagram wrong.
Either way once you start adjusting them you'll know pretty quickly what it's doing.
Three things. The front bumper was tagged by a Caddy coasting backwards into me, the driver's side bumper was slighted on an icy snow pile and I installed high-brightness bulbs. Also, I just wet-sanded, cleaned and UV spray-painted the lenses.Headlights Restoration 2017 Hb.webp
Answered the "why" in next reply. My real problem is... the small plastic nut-shaped devices are breaking and I can't get the lights to move either way. I could break off the plastics and vice-grip the metal but if they're frozen in the lamps... I might as well piss on them..lol
Not yet. I'd like to leave well-enough alone.
If it's not off so much it's sending signals to space and it lights the road in front of you. I'd leave it. If it bothers you try WD-40 let it sit for a few minutes work the screws left to right slightly if it doesn't move squirt a little more let it sit and try again until you get some movement. Otherwise live with it if it's not that off and functions.
