Legit ? About Pulley or belt noise and not about wigs
Yes, there are different engines for different trim/model Tacomas. But, there are only two engines, the 2TR-FE 4 cylinder and the 2GR-FKS 6 cylinder.
A summary is provided here ...
Access Cab:
Model Code | Engine | Drive | Deck | Capacity Weight
__________________________________________________________
TRN265L-CRTSKA | 2TR-FE | 2WD | Long | 1500lb.
TRN245L-CRMSKA | 2TR-FE | 4WD | Long | 1350lb.
TRN245L-CRTSKA | 2TR-FE | 4WD | Long | 1300lb.
TRN325L-CRTSHA | 2GR-FKS | 2WD | Long | 1400lb.
TRN305L-CRFSHA | 2GR-FKS | 4WD | Long | 1100lb.
TRN305L-CRTSHA | 2GR-FKS | 4WD | Long | 1150lb.
Double Cab:
TRN265L-PRTSKA | 2TR-FE | 2WD | Short | 1400lb.
TRN325L-PRTSHA | 2GR-FKS | 2WD | Short | 1200lb.
TRN325L-PRTLHA | 2GR-FKS | 2WD | Short | 1250lb.
TRN330L-PRTSHA | 2GR-FKS | 2WD | Long | 1200lb.
TRN330L-PRTLHA | 2GR-FKS | 2WD | Long | 1200lb.
TRN305L-PRFSHA | 2GR-FKS | 4WD | Short | 950lb.
TRN305L-PRTLHA | 2GR-FKS | 4WD | Short | 1000lb.
TRN310L-PRFSHA | 2GR-FKS | 4WD | Long | 950lb.
TRN310L-PRTLHA | 2GR-FKS | 4WD | Long | 950lb.
So I admit to be misleading based on what I thought I had read.
FlyingLentris in LLOMA
How does 1 not know about apple fritters?
You are missing out
I'm Southern ‍♀️ Maybe it's called something different here. In the coal mining areas, fried apple pies but they don't look like that! I know what an elephant ear is as well as a funnel cake.
