JayQQ97
its not often that you park the rig where most all grease fitting on the prop shaft line up in a row that is easy to access in front of your nose on the shoulder hobbled under the passenger side where fuel tank not in the way
this happened to I yesterday so whilst i was under hand wiping dried salt off of areas i was able to pump in some red tacky into 5 fittings, one has not been done in a LONG LONG speel with all the dirty covering it buried inside uJoint
now one of these fitting acted up and just spit and ooozed the red tacky back... kinda drizzled out
is that an issue? that it will no longer hold accept new grease and is shot?
