10 left to goAre trying to tells us you've collected a souvenir from every state you've been through.
10 left to go
cleaned up that area some more to monitor from the topside... had some dirty oil finger on the side that could be from the oil filter removal and the dribble down on the pan lip area? IDK?
its a wait and monitor
Relax...seeps turn into leaks....just takes time, so be patient.
Any oil leaks are beneficial to preventing rust.i am concerned, though
at the other place with SO MANY GEN1 peeps there are a few that have had to get oil pan seep fixed up
one was from upstate NY with a 95.5 Gen1 but his oil pan had a big rust spot so needed a new pan on his 4wd which was a major task with removing the front diff parts to gain proper access to the pan
Leaks always get worse so you can look forward to seeing that.
10 left to go
7 left togo
Well, if you plan on going to Hawaii you better outfit your truck with a really deep snorkel.10 left to go
