So some more on my BS. I have had every oil change done at the same dealer because they were free. I changed my oil yesterday myself, used Mobil1 0W20 with Toyota OEM filter. I drove the truck today for about 80 miles and it has not driven this good since I bought it! I am not 100%, but I feel as if there was too much oil in it. I drained all the oil (obviously) and put in 6 quarts exactly. Looking forward to driving it more tomorrow!
I just got back from driving it again just because I am in disbelief. I did check the dip stick several times and it seemed as if it was high but it seems hard to read being full synthetic, its so clear. I used a 7 quart drain pan to drain the oil into and it was damn near to the top of it. I refilled the 5 quart jug and the 1 quart jug completely to the top of each jug and had some spill. All I can do is assume, is guess, because all I did was change the oil and filter.did you ever check the oil checkstick after and/or during the OCI?
how much oil was drained out doing the DIY?
It actually takes about 6 qts, and 8 oz of motor oil once you load the filter canister before installing it back on. That will bring the oil between the marks on the dipstick. I wonder if your engine still has a lot of fuel blowing by the rings...reason for thinking too much oil. Rings take longer to seat when using fresh synthetic oil, especially if doing 3-5k oil changes on a new motor. You'll end up with loss of performance to.So some more on my BS. I have had every oil change done at the same dealer because they were free. I changed my oil yesterday myself, used Mobil1 0W20 with Toyota OEM filter. I drove the truck today for about 80 miles and it has not driven this good since I bought it! I am not 100%, but I feel as if there was too much oil in it. I drained all the oil (obviously) and put in 6 quarts exactly. Looking forward to driving it more tomorrow!
Glad it only took 30,000 miles to mysteriously start running better after I did something to it.It actually takes about 6 qts, and 8 oz of motor oil once you load the filter canister before installing it back on. That will bring the oil between the marks on the dipstick. I wonder if your engine still has a lot of fuel blowing by the rings...reason for thinking too much oil. Rings take longer to seat when using fresh synthetic oil, especially if doing 3-5k oil changes on a new motor. You'll end up with loss of performance to.
As far as it driving better due to your oil change...lets just say I'm still laughing at that one. It sounds more like your transmission is starting to smarten up. I was surprised when mine began to do the same...was almost overnight the truck began to preform far better. Maybe some take longer idk.
Its too full.perhaps this Gen2 is being shiitty shifting because the ATF T-IV level on the checkStick is a little over the top hash on the hot side when it is not so brutal cold outside after a long wheel
eyeballing it is around 1 inch over the top hash
IDK
