I like the still factory clutch statement.Mine was. Like new. I now have 10x,xxx on mine. Still factory clutch.
That is another concern of mine about how long a factory clutch will last.
Your suppose to drain the fluid ? Ut oh, i just turned 70,000 miles and the only fluid I've changed is the oil….Those of you with the six speed manual transmission, when you drained your fluid was it clean?
That's excellent, that's one of my worries about when I'm going to have to replace the clutch. I'm just rolling over 102,000 miles and your post makes me feel much better.my rig is nearing 300,000 miles at 26yrs on the factory clutch
Ya dam skippy it's an old thread ! Who the f**k are you and which rock did ya crawl out from under ? You don't just disappear for a few years and then jump back onto this here wonderful website Sparky. Tape…. Back story ?That's excellent, that's one of my worries about when I'm going to have to replace the clutch. I'm just rolling over 102,000 miles and your post makes me feel much better.
(I know it's an old thread)
OMG. So sorry Mr Tape. This AI thing is real and I just wasn't sure. Saw your previous comments here and I see you are absolutely legit. Welcome back to tacomaforum.comYa dam skippy it's an old thread ! Who the f**k are you and which rock did ya crawl out from under ? You don't just disappear for a few years and then jump back onto this here wonderful website Sparky. Tape…. Back story ?
it just so happened that the clutch parts far outlasted the pilot bearing that was finally found to be making the odd noises a few months ago seizing on the input shaftThat's excellent, that's one of my worries about when I'm going to have to replace the clutch. I'm just rolling over 102,000 miles and your post makes me feel much better.
How many miles before the pilot bearing started making noise?it just so happened that the clutch parts far outlasted the pilot bearing that was finally found to be making the odd noises a few months ago seizing on the input shaft
clutch was working just fine
I betcha this replacement OEM clutch (all parts) And pilot bearing do not make it 100k milesThat's excellent, that's one of my worries about when I'm going to have to replace the clutch. I'm just rolling over 102,000 miles and your post makes me feel much better.
why do you say that?I betcha this replacement OEM clutch (all parts) And pilot bearing do not make it 100k miles
I believe if you use new genuine factory parts; replace the clutch, bearing and pressure plate you would get the same results.because i have read here or there a time or two that the replacement is never good as the factory install
i sense that issues and problems are already developing...
