Hmm really? well in my taco I see a difference, even though it's very minor. What I notice is slightly better mpg, more power around 3-4 rpm, and overall it's less sluggish going from 0-60. But the thing I've noticed the most is the noise from the motor is much much quieter. When I use 87 I notice a ping sound, but when I fill it up with 91 she sounds much better. Just my experience with my 08 (4.0l)I have been switching up between 87 and 91 octane and I really can't see any difference. I have also been checking the accuracy of the computed mileage and I find it witching 1/10th mpg of my calculator
Whats ur altitude?Hmm really? well in my taco I see a difference, even though it's very minor. What I notice is slightly better mpg, more power around 3-4 rpm, and overall it's less sluggish going from 0-60. But the thing I've noticed the most is the noise from the motor is much much quieter. When I use 87 I notice a ping sound, but when I fill it up with 91 she sounds much better. Just my experience with my 08 (4.0l)
Ocean level lol all I know. I live in San Diego close to the coast.Whats ur altitude?
U shouldnt have to run premium to avoid pinging imho.Ocean level lol all I know. I live in San Diego close to the coast.
To be honest I just premium because it makes me feel better haha.U shouldnt have to run premium to avoid pinging imho.
Ive always ran premium but that was user preference, and now required with the blower. Im at sea level and up to 1000ft on avg.
Are you leaving the trans in a high gear while going up a grade?
I personally ran a test with each fuel type. I notice when I ran 91 octane on my 08 4.0l taco that I got better gas mileage, more power, and less engine noise. But 87 causes my engine to get noisy, have a bit less power, and has worse gas mileage. This is my observation. What do you guys run?
I have 285/75 (32.8x11.2”) on. My computer says 13-14mpg. Doing the hard math it’s about the same. It might be because the trucks had these on since new. The computer knows no difference.Make sure you manually check your mileage. I see a 4 to 5 mpg difference between the computed value versus the value the truck tells me.
The truck computer seems to be biased about 5 mpg high.
I just put BF Goodrich 31s on my 16 TRD Sport and lost another 3 mpg or more. I went from 21/22 to 18 mpg. The truck still reports 23 and it reported 25/26 and as much as 29 with the stock tires.
BTW, 31s are 3% faster and farther than the speedo/odo readings
I was mainly speaking of the calculations with the factory tires. I have only had the 265 75R17s for 500 miles. They replaced the factory 265 65R17s. My fuel information from the "gadgets" hasen't really jived with calculator math for quite a while. The new tires are only 3% off so I really don't see any reason to reprogram my truck.I have 285/75 (32.8x11.2”) on. My computer says 13-14mpg. Doing the hard math it’s about the same. It might be because the trucks had these on since new. The computer knows no difference.
No need to. It’s a couple mph difference at 65mph.I was mainly speaking of the calculations with the factory tires. I have only had the 265 75R17s for 500 miles. They replaced the factory 265 65R17s. My fuel information from the "gadgets" never really jived with calculator math. The new tires are only 3% off so I really don't see any reason to reprogram my truck.
As far as your truck saying you got 29mpg that’s on a single trip right? When you turn the truck off it says distance driven and mpg.
Like this:
Those are for single trips and is not what the combined mpg for the tank is. I’ve had that display say as low as 4mpg and as high as 28mpg with my 285/75’s.
The display that keeps track of mpg for the tank has always been very close to the hard math calculations for mpg for the tank.
This display:View attachment 14937
I get trip, also tank average and a running average until reset.No need to. It’s a couple mph difference at 65mph.
Like this:
OkI get trip, also tank average and a running average until reset.
The 29mpg was a hi way trip of about 200 miles, non-stop and reasonably level grade.
I work for a well known fuel retailer, there is no midgrade tanks, it just blends the 87 and 91 to give you your midgrade. At least thats the way ours work.I did the same thing. All I run is 92/93. Don't run 89. Got a buddy of mine that runs a tanker and says that when a gas station orders gas i.e. 87 and there's left over it goes in the mid grade (89) tank. Little info for you.
