Bed Lights
Discussion in '2016 + Toyota Tacoma' started by Joonkin, Jan 13, 2017.
  1. Joonkin
    Joonkin Active Member
    I have a 2016 SR5 and was wanting to install under rail bed lights. I'd like to wire it into the existing bed light switch to come on when the one on the rear of the cab comes on. Is this possible?
    Boxerdad214 likes this.
  3. jromo
    jromo Member
    There are led ones that don't have to be wired, they take AA batteries
  4. jromo
    jromo Member
  5. OP
    Joonkin
    I was thinking about those but they only go on one side. I found a thread on another forum where someone installed a door pin switch that makes them come on when you lower the tailgate and turns off when you close it.
  6. scott.c.wickham
    scott.c.wickham Active Member
    I'd like to trigger more lights off the factory bed light switch too. Where to tap in?
  7. OP
    Joonkin
    I ended up hooking them up to a momentary switch that I installed behind the tailgate right above the latch. So now they come on when I open the tailgate and go off when I close it.
  8. Val rodrigues
    Val rodrigues New Member
    C
  9. Val rodrigues
    Costco sells a 6 pak led stick-on with batterys and remote. Have them under my bar and kitchen cabinets. Work great. Now have another set for my tacoma bed. They only cost 19 dollars.
    bestantonio likes this.
  10. bradjolly
    bradjolly New Member
    Just find the wires that go to the existing bed lights and tap Into the. Might have to drill a small hole Into the bed to get the wires thru.
  11. DavidM310
    DavidM310 Member
    Excellent, will look in to this. Can't go wrong with more lights! I'll have this thing looking like a Christmas tree before long.
