Engine RPM’s turning the steering wheel
Discussion in 'General Tacoma Discussion' started by petrw, May 9, 2018.
  1. petrw
    petrw Member
    I have a 2017 SR5 and since I got it when I turn the steering wheel the engine revs up 300 rpm. The dealer said it was normal but I have a friend who has the same truck without this problem. Anyone else have this program?
  3. whippersnapper02
    Normal.
    Bojangles likes this.
  4. cranito4to
    cranito4to Well-Known Member
    I do have the same issue, Thought it was to release some of the pressure on the power steering. I am probably wrong, let me know if you figure out something so I can fix it too if it's something bad with it.
  5. mcklovin77
    mcklovin77 Well-Known Member
    Its normal
  6. whippersnapper02
    When you add a load to the engine when it's at idle, the ECU is going to open the throttle to keep a minimum RPM so the engine doesn't stall and the accessories spin at a sufficient RPM. This extra load could be power steering, AC or even an electrical load.
  7. Crawdad
    Crawdad Well-Known Member
    nailed it
    Cape taco likes this.
  8. OR17TRD
    What size tires can I fit on my stock Tacoma?
  9. whippersnapper02
    155/70R19
    Bogunn, B-Man, Cape taco and 2 others like this.
  10. Cape taco
    Cape taco Well-Known Member
    You cant there is no tire that will fit ! End of subject ! Lol or you can check old posts it may have been answered once somewhere:confused:
    B-Man and OR17TRD like this.
  11. Crawdad
    I think these are your best bet.
    B-Man, Toki, cranito4to and 4 others like this.
  12. Bogunn
    Hey we have the same kind of tires. Lol. Nice.
    B-Man, Toki and Crawdad like this.
  13. Cape taco
    Go lay down bad dog !
    Bogunn and Crawdad like this.
  14. OR17TRD
    I did a search and couldn’t find anything.
    Cape taco and Crawdad like this.
  15. Crawdad
    kp.taco, Bogunn, Cape taco and 2 others like this.
  16. B-Man
    B-Man Well-Known Member
    Cape taco, OR17TRD and Crawdad like this.
  17. B-Man
  18. OR17TRD
    Only with a -69 offset.
    Crawdad likes this.
  19. Cape taco
    Yes definately ,but you may have to change out the fanipply rod bearings ,
    And put in a new gazookafab .
    Bogunn likes this.
  20. Crawdad
    How’s about I stack a few wheel spacers?
    Bogunn, Cape taco and OR17TRD like this.
  21. OR17TRD
    That’ll work
