Jerking While Stopped and Stopping
Discussion in '2005 - 2015 Toyota Tacoma' started by Will Evans, Jun 13, 2018.
  1. Will Evans
    Will Evans Well-Known Member
    Hey Guys, yesterday my truck did something a bit weird and I am wondering if anyone has experienced the same thing. It's an 06 4WD TRD SR5
    When coming to a stop or while stopped, my truck jerks forward hard enough to the point where it made me feel as if the person behind bumped me. It seems to happen at random and yesterday was the first time it ever happened, but only a few times. I always noticed a bit of a jerk when the AC compressor engaged but this was a much more noticeable jerk.
    Anyone else experience this before or know what could cause it? It seems to occur when coming to a stop more quickly than I normally would.
    Will
  3. Bogunn
    Axel wrap.
  4. whippersnapper02
    You can check to see if the axle U bolts are tight but it's probably just good ol axle wrap.
    Bogunn and Will Evans like this.
  5. Crawdad
    Crawdad Well-Known Member
    It's "normal."
  6. pondman
    pondman Well-Known Member
    You mean Axl Worp like time Worp ! And then there's Axle Wrapping paper , with candy canes and Rudolph the Deer right ?
    Crawdad and whippersnapper02 like this.
  7. whippersnapper02
    For Toyota. o_O
    B-Man, Bogunn and Crawdad like this.
  8. pondman
    Thanks Yoda Forum , you be wiser than a Guru ....
  9. AbqHusker
    AbqHusker Member
    A**hole wrap?
    OR17TRD and kp.taco like this.
  10. B-Man
    B-Man Well-Known Member
    Yep!.......A$$hole Wrap! LOL
    kp.taco likes this.
  11. kp.taco
    kp.taco Well-Known Member
    Yes.. Asshole wrap.
    OR17TRD and B-Man like this.
  12. Lil G
    Lil G Well-Known Member
    The wrap that is a axle
    kp.taco and B-Man like this.
  13. kp.taco
    The wrap that is a asshole
    Bogunn, OR17TRD and B-Man like this.
  14. B-Man
    Hahahahaha!!!!
    kp.taco likes this.
  15. OR17TRD
    Don’t wrap my asshole
    vwgtiturbo, B-Man, kp.taco and 2 others like this.
  16. Lil G
    Exit only
    B-Man and kp.taco like this.
  17. smithpa68
    smithpa68 Member
    I disagree with the axle wrap idea here. My 2017 does the same. I say it is the transmission. But it usually happens to me only when cold. I have started shifting to neutral for the first 5 stops and it doesn’t give that bump. Try it.
    Also decelerating really really slowly helps also. I mean really slow!!! I just don’t have the patience for that so I go to neutral.
    Dec1968 likes this.
  18. Tacoma4life
    Tacoma4life New Member
    The automatic transmissions do that for some reason. Just another reason to go with standard transmission.
    Dec1968 and Crawdad like this.
  19. OR17TRD
    So the manual transmission doesn’t ever have axel wrap? Do they have better leaf packs.
    My understanding of axel wrap is that the axel is able to rotate due to weak leaf springs causing a snap back that feels like you get bumped after stopping.
    Am I missing something?
    Crawdad, kp.taco and Bogunn like this.
  20. OP
    Will Evans
    Must have just been axel wrap. It only did it that day a few times. Haven't had it since.
  21. OR17TRD
    Seems to happen to mine more when it’s cold out like 40 or below
