Bojangles
Yeah for pavement warrior, standard load passenger is just fine.... Load range C as well.I believe C rated. Lighter tire, Stronger sidewall, better handling. I am not a tire specialist nor am I pretending to be, if you are one please do lead the way. I am always up to learning something new, seriously.
My truck will not see any extreme off-roading, in fact it'll spend 90% on pawed roads. Why did I go with Toyos? Good reviews, good thread warranty, look aggressive enough without making my truck look like a tractor, price, made in Japan. My personal observations; handling is better than OE Good Year Wranglers (not squishy, running 33psi), slightly noisier, balanced really well, so far did really good in rain, hopefully will be as good in the snow.
Anything heavier will just kill mileage, and your back on bumpy roads. As long as ur happy with the pressure and the tires wear evenly, call it good. I always run 2lbs more in the front. They are responsible for turning and have to carry the load of the engine and trans 24/7. I despise lazy turn in, but that's just me. If I wanna carve a turn I wanna feel the truck lean, not the sidewall flex. I don't have a swaybar, so corners are fun enough
I also run a CPL lbs more in all tires in winter to improve hydroplane resistance.
Happy hunting
And I now can agree with your subjective reply of "better load rating" for your needs and the size of the truck. Kbro2 come in load range E for most sizes right? That would be a nightmare for you, and the same for me.
