Joisey
Oh I am well aware that millions of people use it.
But I blew two snowmobile engines up the first winter I switched to amsoil 2 stroke. Have not blown up a snowmobile engine before or since. Can I prove it was the amsoil, no i can't...do i suspect it was at least partially the problem, yes. Anyway it left a lasting impression on me, and never again. I tear my snowmobiles engine down every summer, and have a close look at it, replacing anything suspect. The engine looked good, so all i did was replace pistons and rings, base gaskets, and head O rings. Yes the heads on it were O rings, not a gasket. The only change I made was switching to amsoil a friend recommended to me. The first engine grenaded on ride 5 the next winter, took out the jugs bad to, so I bought a big bore kit for it, and new crank as well. I replaced ever seal, the crank, bearings, jugs, pistons, rings, new heads, and it grenaded again on ride 4 with the new engine. I bought another identical big bore kit, just the top end this time, not the crank or heads, but replaced the jugs, pistons and rings. I drained the amsoil out of it and switched oil. Rode that sled hard the rest of the season, not a problem. That summer I took the top end apart and looked it over, put it back together replacing nothing but the spark plugs. Next winter I beat the crap out of it all winter and never missed a beat. Next summer I pulled the top end apart yet again, replacing nothing but spark plugs for a second summer in a row. Rode the bag off it all the next winter and sold it that spring still running perfectly.
Coincidence?
Possibly.
But I still can't get myself to trust it.
It's a costly shame when an engine goes south once, never mind twice. I read your post twice, and you didn't mention if you machine uses injection or premix. Just wondering.
