2016 auto transmission vibration
Discussion in '2016 + Toyota Tacoma' started by gar, Nov 22, 2015.
  1. bob259
    bob259 Member
    Some of what I notice I think maybe exhaust harmonics. It will be interesting to see what Toyota comes up with.
  3. Dano72trd
    Dano72trd New Member
    You are right I do notice some aggressive exhaust tones too, but let's face it , it's still a bad ass truck
    bob259 likes this.
  4. Griffy
    Griffy New Member
    Same experience here. Also a high pitched hum at around 50 mph. It seems to only make the noise when not in the throttle then goes away when you get back in it. Not really loud, but noticeable. Love the truck though and expected minor issues on the new model.
  5. blazintaco
    blazintaco Member
    I get a vibration when braking under 20mph. 2016 off-road LB it has almost 1k on it and has done it since I got it. I am pretty sure it's a shudder from the Trans when it down shifts from 2nd to 1st.
  6. Rambo
    Rambo Well-Known Member
    Yes,added Lubegard Platinum and Dr Tanny Shudder fix after draing ATF from pan of aa few qts 3.2 , replaced with 10 Ozs of Lubegard Platinum and 4 ozs of DR Tranny Shudder treatment also by Lubegard , and added 1.8 Qts WS ATF Fluid and all is gone and will do a complete Flush and Fill with AMSOIL or Valvoline WS ATF and also Platinum ATF Treatment again and DR Tranny Shudder fix again in summer !Runs fine and better NOW! Florida Taco Owner !
  7. Brawndo
    Brawndo Member
    anyone heard any updates on this issue?
  8. Rodman
    Rodman New Member
    Same here kept my truck 2 days.
  9. bal64
    bal64 New Member
    have a 2016 trd offroad acess cab with same type of vibration at 15 to 30 mph more on decell very noticeable have met with a fts from Toyota no word on fix have tried different things with no luck.you need to make sure a case is made on this with Toyota or not much will get done. this is how they find out there is problems.it is a driveline vibration we have proven this for sure.
  10. mjk
    mjk Member
    I opened a case with Toyota special care. I explained the general concerns about the auto transmission in the V-6. I had an agent look into any potential updates on the 2016 transmission. None are in the works. I put in a request into the specialists (engineers) to look into it. The agent said we all need to open a case to make a difference. Google Toyota support & help make a difference if you can. I have a 2016 Limited.
    tony45 likes this.
  11. blazintaco
    blazintaco Member
    at first I thought it was a Trans shudder. But its something with the driveshaft.
  12. Gregbiggs82
    Gregbiggs82 New Member
    I have a 2016 trd off road access cab. It had a vibration around 25 mph ish. Vibration was more pronounced on deceleration. After arguing with the dealership that it was a driveline angle issue (common on the past years) they opened a case with toyota. Low and behold they ordered leaf springs with different blocks to change the angle and a damper that goes in the steering wheel. All parts that fit i think 05 and up that were in stock at the warehouse. There is plenty of info on this subject if you search. Parts installed were 48210-04830 spring r/r 48220-04470 spring l/r 45713-35040 damper steering. The vibration is 95 percent gone. I will live with it unless i get a pinion seal leak and i will flip shit. The truck has 7500 miles. Its done it since new.
  13. TacoRick
    TacoRick Well-Known Member
    Mine does it too. I just had my truck at the dealer for it. I specifically asked that they check the driveshaft, but instead they did an alignment and balanced the wheels. Obviously this had no effect on the vibration. I'm going to try a different dealership and hopefully get the same fix that you did.
  14. wilber
    wilber New Member
    I have a 2016 DBL TRD off road that i purchased on the last day of the year in 2015 it has an insane vibration in the gas pedal, steering wheel that emanates into the entire cab i made a video of a bottle of water sitting on the lid of the center console and the water was shaking insanely while stopped at a stop sign it now has 28000 miles on it and it seems to be getting worse it even feels like it cycles i have taken it to the dealer in santa fe 3 times and the toyota regional engineer has looked at it and they keep saying that it is "operating to manufacturers specs" when sitting in stop and go traffic the headrest of the passenger seat vibrates like the magic fingers machine at the motel 6 from back in the day i feel nauseous and dizzy driving this thing after only 4 hours i also have a dodge 4x4 3/4 ton diesel with over 200,000 miles on it that is smoother than this vehicle i love the truck except for the vibration i don't mind that it only gets 14-16 mpg on the highway and that it wails like a banshee even after having the door mouldings replaced twice it may be "normal" but its not "right" i have contacted a law firm in california that is working on another class action lawsuit against toyota and they are going to do some research as well if enough people come forward maybe toyota will acknowledge that there is a problem and come up with a fix toyota is notorious for denying engineering flaws my 2000 tundra comes to mind the rotors were warping every 3000 miles and they said it was normal finally they issued a recall and started manufacturing rotors that were not prone to warping....
  15. abramtrek
    abramtrek Member
    Did you get the update from the dealership
  16. wilber
    wilber New Member
    i had one flash done november 3 apparently there was another one issued on november 15 i took it in and they didn't do it i now have a case started with toyota they are being very lame said there are no reported issues when i mentioned this forum they said they do not acknowledge these forums.....
  17. Timber
    Timber Member
    Is this a non-issue for the 2017 TRD off-road?
  18. OR17TRD
    I don't have this issue on my 2017 off-road. I have other issues but not this one. They are fixing this issue with new leaf springs and a shim added and a steering wheel dampers. I'm thinking most of the 2017 come with these done. I haven't heard of many people with 2017's complaining about this issue.
  19. TacoRick
    The last I heard this tsb doesn't include TRD OR's. Have you heard differently?
  20. OR17TRD
    I haven't heard of this issue with the 2017. I was replying to timber. I don't have it on my 2017 off-road.
  21. Allthumbs
    Allthumbs New Member
    I have 2017 sr5 4x4 300mi, no lift, have a vibration 55-65 mph. Feel it in steering wheel and see it in rear view mirror
