2018 Tacoma lift kits
Discussion in '2016 + Toyota Tacoma' started by toyotatavoma17sr, Apr 10, 2018.
  1. okichewy1
    okichewy1 Member
    Nice!! Same color truck and model I have. Have been looking at your setup for a while, guess I need to pull the trigger and get it done.
    Quick question? What Dakar's did you go with in the rear? I assume you got this kit from Headstrong.
    Travisjb21 likes this.
  3. okichewy1
    okichewy1 Member
    If you purchase the set through Headstrong (and they build them), Headstrong will cover the manufacturer's warranty for them though.
    OR17TRD likes this.
  4. bumpedmyhead
    bumpedmyhead Well-Known Member
    On your lift, can you increase the 5100s and take out the rake?
    JonRod likes this.
  5. jdr3366
    jdr3366 Well-Known Member
    Alright. Lift this, lift that.
    Here's the only lift you need to do. Everything else is window dressing
    [​IMG]
  6. OR17TRD
  7. Crawdad
    Crawdad Well-Known Member
    OR17TRD likes this.
  8. Bogunn
    JonRod and OR17TRD like this.
  9. jdr3366
    That's gonna leave a bump.
  10. OU81taco16
    OU81taco16 Well-Known Member
    Yup
  11. Glenn671
    Glenn671 Member
    Following, I almost settled for junk country 4” lift, but after doing a lot of reading I might go this route as well.
  12. Glenn671
    Glenn671 Member
    Did you get the to assemble the coil and strut?
  13. okichewy1
    okichewy1 Member
    Yeah!! Much easier and if they assemble it, HS offroad will cover the warranty for the OME springs.
  14. okichewy1
    okichewy1 Member
    I ended up with 3" exact in front and 3 7/8" in the rear. Went with OME 888s, 5100s and Dakar HD leaf springs
    OR17TRD likes this.
