9-5-22
Found this set with 75degree offset + pouch + more sizes
https://www.amazon.com/dp/B08FB12R2...pY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU&th=1
I have labour to do around 2 fuel tanks!Heavy work around flammable gases. Brass....no spark. No BOOOM!!!
Ok how about to hammer free UCA from ubjI guess using it on some stubborn hardass's head. Actually, likely hitting something like a steel object, but you don't want it damaged. Iron pipe threads comes to mind.
Whatever tool them monkeys used to get my truck knuckle free did big damage to the UCA and the bottom lbgI'd use a Ball Peen hammer first.
That hammer may be too large to swing in that area.
Toyota dealer service shop would not dare use that kind of tool on steering knuckles would they?Generous use of air impact hammers is a common practice in semi-professional shops.
And spoil all that fun trying to remove the old ball joint? That'd be way to easy.FWIW. Control arms are available as replacement parts with bushings and ball joints installed. Sure will save a great deal of effort.
