I just completed a Disc brake job on my '06.  New pads and rotors on both sides.  Passenger side also got a new caliper because 1 of the 4 pistons was stuck.
The rotors were stubborn to remove.  Generous use of PBlaster in all 6 lug holes and the jack screw holes coupled with a BFH.  Turning, pounding, turning, pounding, swearing, more penetrant, pounding, turning........eventually there was evidence of movement, more penetrant, pounding turning....they came off.
Wire brush, brake cleaner, blue rages......then follow with sparingly applied copper based anti-seize on the hub contact points.  Reassemble.
I believe the old pads were OEM pads.  Very, very, very thin.  Below the minimum threshold of 1 mm.
In the last couple weeks I've installed the following on both sides, Front axles, pads, rotors, sway bar links, 1 caliper and tie rod ends.  Check upper and lower ball joints....no play.  Visually examined bushings....they are old yet still functional.  Next big tickets are tires and battery and head unit.  Prolly need shocks in the Spring.   Based on maintenance records they have roughly 60 kmiles on them.  Starting to get a some porpusing after big pavement undulations.
