If water has oozed out of the joint, then that joint is compromised. It will have rust in the races and rollers. Rust (FeO2) is very hard material that will work like grinding compound. Suggest to replace that U-joint and probably all the others too.still there is this clunky... but NOT all the time. so i do not get it get it at all!?
to properly check that rear-most uJoint that likely has NOT ever been greased with new red tacky until i did it (watery oozed out then)
to properly check would the driveshaft need to be undone from 3rd memeber to get a better feel onit?
I've wedged a small pry bar between the u-joint, and the driveshaft, while trying to twist it to see excessive play in the joint. If water ooz's out, that joint isn't far behind to fail.why do u need a prybar?
i have seen it done on video with two hands onit
hold one side n try to twist move other side?
but i think prop shaft was unattached idk
Perhaps your dealer is using KY Jelly as a lubricant as they service you and your truck.That is what I am afraid of
Unless the dealer in the past dozen years years used some grease that is very very thin to grease that at the oci
That is has the appearance of water
