Does Remote Start require a Remote Connect Subscription?
Discussion in '2016 + Toyota Tacoma' started by Nathan, Nov 21, 2021.
  1. Nathan
    Nathan Administrator Staff Member
    I found the following instructions for remote start
    Press the LOCK button on the remote.
    Press the LOCK button a second time within 1 second.
    Press the LOCK button again, this time holding it for 3 seconds. The vehicle will start.
    I couldn't get it to work until I set up my vehicle in the Remote Connect app. Now it works.
    Question is, when my "free" subscription ends in 12 months does the Remote Start feature using my Key Fob stop working?
  3. Jersey Black Beauty
    Jersey Black Beauty Well-Known Member
    Don’t think so. Assuming your referring to your new truck?
    My 2017 has Factory Remote Start,,no subscription needed!
    New ones have Apple Play,right ? Did you have to put the App on your phone?
    I would think you set up your phone via blue tooth on the truck and that’s all
  4. B-Man
    B-Man Well-Known Member
    My '18 Sport starts with 3 hits of the lock button......mine is a 12voltsolutions!
  5. OP
    Nathan
    Yup, the 2022. It has Apple Carplay.
    It wouldn't work until I put the app on my phone and registered my vheicle. Once I did then the keyfob started to work for the remote start. It doesn't seem like the two should be connected but somehow they are.
  6. Jersey Black Beauty
    Nathan,,you have keyfob and push button start?
  7. Jersey Black Beauty
    My 17 is like B-Man,,,3 pushes on the lock
    ScottyP13, Scott Wyman and B-Man like this.
  8. Jersey Black Beauty
    I believe with have Etune though
  9. OP
    Nathan
    You have to press lock, press lock again, and then press and hold lock for 3 seconds.
  10. Jersey Black Beauty
    Yes sir:):)
  11. hatred
    hatred New Member
    New here. Just got my 22 Barcelona Red SR5. I have an android and installed the Android Auto app. What do I need to download in order to get the auto start to work? Tried the press twice and hold but it didnt work.
    Thanks, Tony
  12. Scott Wyman
    Scott Wyman Well-Known Member
    Seems to be an issue with the new Tacos.:mad:
    Jersey Black Beauty and B-Man like this.
  13. OP
    Nathan
    Welcome to the site Tony.
    I have a 2022 TRD OR. I had to download the Toyota app on my phone and create an account. I then added my Truck using the VIN number and it gave me a verification code to verfiy ownership. To enter the code follow these steps.
    Turn on your Toyota vehicle and use its Audio Multimedia touchscreen and perform the following steps:
    1. Select "Menu"
    2. Select "Apps"
    3. Select "Communications"
    4. Select "Remote Connect Authorization"
    5. Enter the Authorization Code
    Once it was setup I coould then use my key to start the truck.
  14. TacoTruck2019
    TacoTruck2019 Well-Known Member
    I just glanced at an article over the weekend that said that Toyota remote start did go to a subscription service. I'm pretty sure the article was on Google. I wasn't that interested in it as mine don't have remote start so I don't know all the ins and outs. Could be if you start from app on you're phone you need a subscription but if you just push the buttons on you're key you don't.
  15. Olli K
    Olli K Well-Known Member
    My 2021 worked with just the key fob at the dealership before I even took possession. The sales guy took us out to look at it and showed us a bunch of the bells and whistles on the truck. I tried the app but deleted it. Never bothered with setting it up or connecting it to the truck.
    But as far as a 2021 TRD Off Road, remote start with the key fob works without having to set up the app on your phone.
