bdarnold12
The oil itself may last that long but with vvt and any number of other stuff being operated and controled by oil/oil pressure I believe clean oil is just as important as good oil.
			Most synthetic oils are actual proven to 15k these days. Don’t fall for big oil marketing.
Regardless of mountains of information. Change your oil and filter every 5k. Change transmission fluid every 60k. Rotate tires front to rear at every oil change. I've run Toyotas over 200k and have never had a transmission or engine problem.I’m fairly new to the 3rd generation Tacoma. I bought a 2017 trd sport with 20K miles on it. Changed the oil right when I bought it and my maintenance light came on at 25K. I’ve been hearing that 3rd gen Tacoma’s are 10K mile oil changes not 5K, is this true?
I was surprised to see changing the atf every 60k miles, or even reading its lifetime. I had an older asin auto transmission in my tundra which needed to be drained of 4 qts, and refilled every 15k miles which i followed exactly. That truck never had a problem with its transmission. With this tacoma it appears similar imo. I'm even leaning toward a 30k mile atf service.Regardless of mountains of information. Change your oil and filter every 5k. Change transmission fluid every 60k. Rotate tires front to rear at every oil change. I've run Toyotas over 200k and have never had a transmission or engine problem.
Same for mobil 1 extended mileage being scarce in 0w-20 here to. I can find 5w-30 plentiful in the same grade....go figure. As far as the filters i buy the toyota ones off ebay when someone offers a deal.Please be aware, not all synthetic oils are the same. There are 3 grades of synthetic oils. The way I describe them is by the length to replace the synthetic oils.
For instance Mobil synthetic oils, if it says replace every 7,500 miles , this is a grade 3, If replace every 15,000 miles this is a grade 4, and if replace every 25,000 miles this is a grade 5, Amsoil makes a grade 5 synthetic oil.
I think purple oil is a grade 4.
I find it harder to find the Mobil grade 4 & 5 where I live. Just that you need a matching oil filters too.
Never any harm to replace the motor oil sooner, maybe just the cost. I am disappointed by the oil filters system the Tacomas have. I think they did that on purpose, to make it more difficult for the diy .
Once my dealer maintenance plan ends, I will be doing my own oil changes. Mobil one for sure. Learn about Mobil one in the 70’s and that is all I use to present in every single vehicle I own.
I saw a conversion kit to regular filters, not a easy thing?
Follow what the owners manual recommends for the car. Just my opinion for these 3rd gen tacomas, 5k miles, or 1 year whatever comes first if driven low miles with lots of city use. If mostly highway miles, 10k miles, or 1 year whatever comes first.
