4XTIME_TACO
I change mine every 5K because I offroad a lot and drive it like I stole it...
I hear ya drive it like ya stole it and rotate tires and oil every 5kI change mine every 5K because I offroad a lot and drive it like I stole it...
I think your truck is 7.5k miles for oil changes. They didn't list synthetics for it back then.The conventional oil looks swell still at 6k
That's what I told them in the most furthest east yota dealer found in the USA to put on in there
When I changed mine last fall around 10k miles, it still looked pretty good. I used mobil1 0w-20w. The filter looked a little discolored vs the new one.
the car nut would shake his head at U
do you stop and go drive most of the time?
sit at idle?, short trips?
I do about 50/50 city highway now, depends on the days. Sometimes it's more highway one week than another and visa, versa.the car nut would shake his head at U
Screw the car nut. He's just covering his butt. He doesn't know how everyone drives their vehicle, or where, or what oil they use, whether a dino, or synthetic. I did 90% highway when I owned my tundra using mobil1 with 15k mile oil changes. I wouldn't be afraid to reuse that oil in my mowers. I figure with this 3.5 using low tension rings, and all 10k miles, or once a year is fine. No sense wasting resources. If the truck last's me another 20 years, I should be pushing up weeds by then.
No, but I likely will this fall, or next spring. Truck should be close to 30k miles. I'll change the transfer case and rear differential gear oil too. Same as I did for my tundra.have U changed the front diff gear oil in your current rig?
I don't have a gen2, it's a 3. I'll replace the air, and cabin filters. Imo, only clean the maf sensor if it really needs it (cel). Throttle body at 40-50k miles is good enough. Spark plugs are the iridium type 60k miles.@tacojoel
Don't forget the other Gen2 30K interval tasks.
Front Diff Change Rear Diff Change Transfer Case Change MAF Clean Throttle Body Clean Spark Plug Change
Close enough, at least its not one of those gen1's.Sorry, thought you had a Gen2.
whuts wrong with Gen1Close enough, at least its not one of those gen1's.![]()
nothing......10 years ago.whuts wrong with Gen1
